- May 27, 2019
- 1,621
- Plaster
- Hayward Aqua Rite Pro (T-15)
My pH rise has been quicker than usual, so today I did a full chemistry check.:
FC 9. CC 0. pH 7.8 (I added acid to reduce to 7.6 2 days ago), TA 90, CH 425, CYA 60, SALT 2900, BOR 25, Water Temp 89, Calculated CSI 0.21
CYA is 60, lower than my normal 70-80. With water temp regularly going above 90, a reduction in CYA is not unusual. Adding 4.25 lbs CYA...I use a version of the sock method using a very fine mesh net and place it in front of my old pressure side pool cleaner wall socket with the pressure side pump turned on. CYA is already gone! It took about 1 hour! See pictures below.
TA is 90. It was 70 early in the season but is creeping up. I know this is driving the pH rise. We have not had significant rain for several months; my water additions are driving my TA up. My CA (carbonate Alkalinity is around 65, which puts my pH ceiling around 8.25. I added a gallon of MA (which lowers TA by 20) and I'm running my submersible pump as a fountain to raise pH. I think I'm going to have to do it again to get my TA way down before I up my Borates from ~25 to 50. With the CYA fixed and TA fixed, my CA should be around 38, with a pH ceiling of 8.0.
CH is 425. The real worrisome thing is my rising CH. Again, the constant water evaporation and water adds are also driving this. I'm up to 425 and it is only mid-July. I really do not want to do a drain...But with the SWG, I am always concerned about scaling. CSI is up to 0.21 with a pH of 7.8! This is why I'm attacking the TA. It looks like I may need to run a slightly lower pH to keep CSI slightly negative. If I get my TA to 70 and my keep my CYA at 80, I now need to adjust pH at 7.8. Looks like my new target pH is 7.6 when the pH gets to 7.9.
I have a feeling that a 25% drain and refill is in my future...And then I have to FIX the chemistry again....
Modified Sock method:
Cheesey Submersible Pump Fountain
