Hi there,
I have a home made controller with a pH probe that I mounted on the tubing after my pool filter.
So far I've had no luck with value accuracy as you can see in the screenshot.
I also read the value could be disturbed by residual current in the water and you need to ground the water to earth.
Any idea?
- Pool water in a jar: Stable
- Pipe with pump off: Fluctuates
- Pipe with pump on: Fluctuates wildly
Any idea?
