- May 23, 2015
- 25,707
- Plaster
- Pentair Intellichlor IC-60
Holy cow
Um...I mean, ok, remain calm and walk slowly away from the edge of the pool....try not to breathe too deeply....
Just kidding. But that is a seriously AWESOME picture!! What exactly was the "shock" you put in composed of? Cal-hypo, di-chlor, nuclear-algae-death powder? The green, frothy water is a little .... unique ....
OK, I'm going to suggest that you add nothing else to the pool except for bleach or acid...and never those two together. I'm also going to suggest that you try to get a phenol-red pH test just so we can see where you're at. Some of those simple test kits come with an alkalinity test as well (OTO for chlorine, phenol red for pH and bromothymol blue for TA test). If you're not adverse to spending some more money on those, it could be helpful. They're also not a total waste as I use mine for daily quick testing and save my good Taylor kit for once-a-week in-depth testing. They quick tests are not as accurate as Taylor tests but they are a good indicator to tell you if further investigation is required.
Your pool water can be fixed, it's just going to take a lot of patience.
As for bleach, one thing I forgot to mention that is super-important - ALWAYS check the date codes on the bleach. Chlorine degrades over time and the highly concentrated stuff (10-15%) degrades faster than the household stuff (6%-8.25%). So the date codes matter especially if the supplier leaves the bleach on a pallet in an uncontrolled environment (heat and humidity is bad for bleach). You can search TFP for how to read the date codes. It's typically two numbers XX-YYY where XX is the two digit year (e.g., 15 = 2015) and the YYY is the day of the year (e.g., 205 = 205th day of year or Jul 24th). If the bleach is high percentage (like 12%) and more than 6 months old, it could very well NOT be 12% anymore. Freshest is best, just like vegetables.
