Hi all,
I'm a long time lurker who has learned a lot from these forums. I've been in the pool business over a decade, but I've got a problem that has me stumped.
I have a customer whose pH is consistently around 8.2 or 8.4 every week. It's a salt pool, gunite finish, with a spill over spa. Tuesday the pH was 8.4, TA was 100.
As an experiment I adjusted the pH to 7.4 and then shut the system down overnight. Twenty four hours later, the pool pH was unchanged, but the spa had risen to 7.8. I put a chlorine tablet in the pool, disabled the salt system, and 48 hours later pH was 8.0
My two competing theories are that the spa finish is improperly cured. Or that aeration from the spill over spa is the problem. Or a combination of the two?
This customer is very attentive to his pool and wants a solution. I've had this problem with a handful of other pools in the area, but most people don't care so long as it's safe to swim. He is having significant scaling issues, and I'm trying to use this opportunity to find a long term solution to this fairly common issue.
I'm thinking a borax product may be an option, but I'm open to all suggestions. Any help at all is greatly appreciated.
