In-ground Gunnite Pool/35000 gal.
The water was green when the pool opened on 6/2. Poured in 5 gal. liquid chlorine and ran filter for 24 hours. The first reading after 24 hours was as follows: FC=5, PH=9, ALK=120, CYA=100, and water was still green.
On 6/3 added 4 lbs. of dry acid to lower PH and ran filter for another 24 hours (filter has been running pretty much non-stop). Numbers on 6/4 were: FC= 0, PH= 8-9, ALK= 100, CYA=80, and water color was turning to sort of cloudy turquoise. PH was still very high and have no idea why FC came out 0.
On 6/4 added additional 4 lbs. dry acids. After aprox. 4 hours interval added 2 lbs. powder shock. This morning (6/5) water color has become cloudy bluish. Still can not see the pool floor. The numbers haven't changed much: FC= 0.5, PH= 8-9, ALK= 80-100, CYA= 60.
I have back washed the filter many times in last 3 days. I suspect the cloudiness in water is due to very high PH (could there be another reason?).
What else should I do to lower the PH and remove cloudiness from the water. Any guidance is much appreciated.
