1. Background. I emptied, cleaned, and refilled my hot tub (300 gallons) in fall. We did not use it almost at all since then, and I didn't really maintain the chemicals. Now my wife decided she wants to start using it again. Last week, I did all the tests, balanced the water and she went in. She complained of it feeling like sandpaper. Darn. I read up and I guess that is what we call scaling? Makes sense because my PH was through the roof. Started doing some reading and found the sticky here 'how to maintain my hot tub with chlorine'. Perfect! Just what I was looking for.
2. What I did.
a. My calcium hardness was super low. I brought it up to 120.
b. My TA and PH were both super high. I brought the PH down to 7.0 about 5 or 6 times until my TA is now 50.
c. My FC was low but not quite 0. I have been keeping it between 3 and 6.
d. My wife scrubbed the entire hot tub to get rid of the 'sandpaper'
Most recent test results:
a. FC 0.8 (added to bring to 6)
b. CC 0.4 (ok)
c. PH 8 (added 9 grams/0.3 ounces of PH-)
d. acid demand test, 1 drop.
e. TA 5
f. Calcium 120
3. Where i'm at, what I need help with.
a. Every time I test it now, the PH is 8 but the 'acid demand test' that comes with my test kit only calls for like 9 grams of dry acid. I know, I should start using muriatic acid now that my TA is at 50 but I don't have any with me so
Why is it still drifting up so fast? How do I stop it from drifting so fast?
b. There is like a yellow scum that is sort of loosely floating at the bottom of the seats? What is that?
c. Should I be worried about any scaling that would have taken place inside the piping? If so, what do I do about it?
p.s. this site has been such an awesome resource for me to take care of my pool. It is so easy, I didn't expect the hot tub to be so much more work! Thanks all!
2. What I did.
b. CC 0.4 (ok)
e. TA 5
f. Calcium 120
