Ph Constantly High
Swim138
55
Hi all, I'm in Southern Arizona. I cannot keep my pH down. The water is extremely hard here and I think *maybe that has something to do with it. I test pH weekly and it's always 8.5. I'm spending a small fortune in muriatic acid to keep trying to bring the pH down to the TFP recommendation. Any suggestions on how to keep the pH in the recommended range? Or should I give up. Thanks all. Oh, I did drain and refill the pool after 5 years and I still have the same exact problem.
-Cheers
Post a full set of current test results from one of the recommended test kits
Test Kits Compared
How old are your test kit reagents?
How do you chlorinate?
Are you on city water?
Much of the Tucson water comes from the CAP canal and it high in CH.
What is the pH, TA and CH of your fill water?
FC
CC
pH
TA
CH
CYA
Water temperature
Reactions: Bperry
-Cheers
In addition to above advice, try posting a picture of the pH test color and let’s double check. Lots of people think it’s higher than it really is. It’s sometimes a hard test.
