- May 27, 2019
- 1,624
- Plaster
- Hayward Aqua Rite Pro (T-15)
Normally, I go from 7.5 to 7.8 pH in about 3 days. I add about 1/2 Gallon of Acid, twice a week. TA is 70.
For the past several weeks, I have had a solar pool cover on my pool. Since I've had the cover on, my pH has been almost unchanged. We have a fairly windy backyard so I'm guessing my pH change is CO2 outgassing. The cover is on 24/7, except when I'm swimming, maybe 4-8 hours per day - 3-4 days a week. Pool is uncovered less than 24 hours per week.
For next year, when the pool is fully open, is there a way to keep the CO2 in the pool? I see some people try to stabilize pH by adding CO2. As a home brewer, I know that CO2 is cheap. If I get it in 20 or 40 lb tanks from a welding supply, it is very cheap. Anyone have directions on how to add CO2? I have a line from a defunct ozone producer, which might be of use. I could also use a CO2 beer stone embedded in the wall of a piece of PVC pipe. Is there some sort of flow regulator for this application? I like the idea of an automatic system. I do not need a pH control, as I can adjust it like my SWG.
