Hello guys.
Just giving a little heads up to everybody who use an automated pH calibration system.
Mine is an astral pool Ph Basic 5l/h. It has a pH sensor after the main pump and filter and a muriatic acid 32% inlet before the swg cell .(swg cell is the last in line on my main feed line to the pool) Just to be clear my setup is
ool main return-main pump-main filter-ph sensor-muriatic acid inlet-swg cell-pool)
I have noticed that my TA was drifting low (40 to even 30) needing a lot of baking soda to correct. I had the pH set to 7.8 on the astral ph pump. I then checked the ph with a classic taylor kit and it was between 6.8 an 7.2 (can never be exact with these color tests!!) I doubled checked with another pH kit from a neighbor. I then recalibrated the pH sensor but it still showed 7.8. I bought a new pH sensor to be 100% sure: still 7.8.
I then took a bucket of pool water and removed the sensor from the piping and used it in the bucket........7.2 !!!!!!
So all this time I have been calibrating a 7.2 pH thinking I was on 7.8. That explains my low TA as well.
Anyway I now have the pH pump set at 8.4 and I am geting an actual pH of 7.8 (which is what I need to have balanced water as per pool math calculator).
It seems that turbulence in the pipes increases the pH topically ( ?) and the sensor reads high....Anyway ,I just thought I shared my experience and warn anyone with a pH sensor to doublecheck their readings.
Cheers
Cheers
