pH Balance product
Sjde
321
Denver CO
Another hot tub owner recommended pH Balancer to me -you add the entire bottle on a refill and he said it kept it balanced a long time, till the next refill. In a Leisure Time product called pH Balance, the ingredients are dipotassium phosphate and monosodium phosphate. Has anyone used this & can comment on it? We tend more to have a problem with low alkalinity that with pH.
Phosphates are a pH buffer like carbonates and borates (and cyanurates). And the nice thing about phosphate buffers is that they are most effective (or have the highest buffering capacity) at a pH of 7.4 which is perfect for recreational waters. However, there is always a downside...phosphates will react strongly with calcium to form an insoluble precipitate (calcium phosphate and calcium hydroxyapatite ....the same stuff your teeth are made of) that is immune to removal even from the strongest of acids. So, one can use phosphate buffers in a spa, but realistically the CH has to be very close to zero or else you could get scaling all inside your plumbing, the heater especially and your filter. It may be possible to add the buffer to the water, create a bit of temporary cloudiness (scale) and then have the filter remove most of it but that's taking a risk. I certainly would not do that with the heater running as the heater will be most susceptible to scale. If you can fill from a water softener that reduces the CH to zero, then you could use that product to help balance pH.
That would rather high for the phosphate buffer chemicals. It will react to form calcium phosphate scale and probably clog up the filter. You’d really want the water to have as low a CH as possible. You can always try it, but I would start at CH of 75ppm (or lower if possible) and see how it goes.
