Linen has pointed out a great place to start reading. Here is what I wrote at the same time:
Why do you want to flow rate? There is really no need to know it ... I don't ... anyway ...
I think some reading of Pool School over the closed season would help with your understanding.
Your CYA appears to be reasonable (which is surprising based on the amount of tablets you are using ... which could just point to inaccurate testing at the pool store). You need to realize that the tablets are adding FC and CYA and lowering the pH. The FC is consumed by the sun and organics, the CYA stays in the pool. Eventually the CYA gets too high and pucks with NEVER be able to add enough FC to prevent algae.
What "shock" are you using? If it is powder, that is either adding more CYA or CH ... both of which are bad when they get too high.
You are at a point (assuming the CYA is correct), that you need to STOP using tablets and stick to liquid chlorine / bleach to raise and maintain your FC.
Algae does not always make the water green, or be visible on the pool. Sometimes it just makes the water cloudy or sometimes it is just hiding somewhere.
I would recommend doing the OCLT which would confirm the presence of algae or something that is consuming the FC in the pool, but that really requires the FAS-DPD chlorine test to do correctly. That test is also required to correct follow the shock process.
If you just want to limp by for the rest of the season and the water is basically clear, just keep adding liquid chlorine every day to keep your chlorine test reading high (you can go pretty high on the FC before it is not safe).
If you provide your pool and equipment details in your signature (specifically volume), I can give you an idea of how much bleach you should be adding every day.
