PENTAIR WHISPERFLOW COMMUNICATION CABLE
ahha0527
In The Industry
Jul 11, 2022
45
Los Angeles
Hello
I noticed the whisperflow communication cable
356324Z is 25ft long… the pump and the panel are about 50 ft away..is it possible to buy two cables and configure/attach wire them together so it can reach that far?
has it been done?
thanks
You will find information about the cable and connector at Pentair Superflo VS Pumps - Further Reading
I don’t think the length should be an issue.
Read the article and figure out if you should build your own cable.
so if i need a longer cable than 25ft what specific cable can i buy in the market to make my own?
i think it only mentions about where to buy a connector pin to attach to cable
Either make your own or splice two cables together.
I would build a cable so that there are no splices to cause problems in the future.
The 50’ distance was a lack of good planning and design of the equipment pad.
Reactions: Jimrahbe
