Pool Pump: 0.5HP Pentair WhisperFlo 90GPM
Pool Filter: Pentair EC90, 90GPM
0.5 HP = 372.85 Watts
Measured amps: 5
Voltage: 230V
When I turn on the pump I see a load increase on my solar inverter by approx 1200 Watts and i am confused by that since the pump should be running closer to 400 watts. To make sure the load is correct I've measured the amps with the exact same results.
My electrician came already to check all wirings, tightened screws and checked the capacitor. No issues found.
The pump strainer was cleaned today as well as a deep cleaning of the filter to make sure the pump is not doing extra work due to a dirty filter.
Pool Size / Plumbing: 34 cubic meter / 9000 Gallon Pool. Pipe distances are short, pump and water surface are almost level but slightly lower... so gravity can prime the pump.
