Have a new heat pump and pump install. Each wired separate into separate breakers. When I turn on the heater, it instantly kicks off the pool pump and then within a second, the heat pump errors on low water flow. I have clean baskets, backwashed filter, high water levels. Pentair says they have never seen it but maybe an electrical
Issue or drive issue on the pump. It has run for 8 hours before and works well but other than that, will not start up 95% of the time. Power stays on to everything and the pump will kick back on after 3 seconds and the heat pump goes into restart mode. Thoughts?
