Hi Folks,
This is my first post. I tried to search the forum before posting and found one post from 2020 that seems to apply.
I had a VS3050 pump that died (the casing rotted most likely due to a leaky seal, but I digress). I bought a used pentair pump with part number 350305 (is this a VSF?) and swapped it in for the 3050. Plugged in the serial connection and the basics seem to work. (Original 3050 RS-485 had 5 pins and the new one has 2 but I understand that this is ok as only two are used?).
I have a few problems with the automation.
When I turn on the spa, it doesn't turn on the pump. When I turn on the waterfall, it turns on the pump but to a different rpm.
I'm starting to think that I might need to flash the firmware on the easy touch. Hopefully, I don't need to replace it completely.
Here are all the relevant versions:
Easy touch 8
Soft: 2.060
Boot: 1.010
I have the pentair screenlogic installed - version 5.2 build 738.0.
Anyone have any ideas on what I should do in order to get the spa and water features working again?
Andy
Easy touch 8
Soft: 2.060
Boot: 1.010
Andy
