- Dec 13, 2018
- 436
- Vinyl
- Pentair Intellichlor IC-60
Do the Pentair valves bug anyone else? The handle is 90 degrees to the pipe when open and in line when closed (the little off tab is the indication). This goes against everything I know about valves. Typically, the handle is inline when the valve is open. Is there a handle configuration that I can set up? I tried to unscrew the top handle and rotate, but it does not fit that way. The pictured valve is in the closed/off position.
