Staring up my Pentair ULtratemp heat pump this year, it makes a rhythmic thumping noise, about once per second. Too slow to be the fan hitting something. Sometimes the thumping stops after running a few minutes, sometimes it doesn’t.
Does anyone have an idea on what causes this? Maybe a belt slipping but that’s just a guess.
In addition, the fan won’t shut off unless the breaker is shut off. I press the on/off button and the green light will go on and off but the unit keeps running regardless. Evryrging on the control panel seems to function normally except for this. An electrician is coming out in a few days to see if there is a bad connection or control panel issue. Any thoughts?
The unit was fine in the fall when I closed the pool.
