Pentair UltraTemp Heat Pump Service in VA
ForbiddenRooster
0
28
Stafford, VA
Having a hard time finding someone to take a look at my heap pump in Stafford, VA. It does work as intended most days, but often the screen freezes upon startup or shows the incorrect info (e.g. actual temp = 163*). Any recommendations on a service provider or possible solutions I can try would be helpful. To date, I have reset/tested the circuit breaker, reset the panel, and pressed the heater reset in the panel. Pentair UltraTemp 110 with EasyTouch Control System all install in 2018.
Thanks!
Sounds like the control board needs replacement.
