- May 12, 2023
- 6
- Plaster
- Pentair Intellichlor IC-40
Our system is controlled by the pentair intellichem / intellichlor which keeps our pH (Muriatic acid tank) and ORP mostly within normal range
On water testing, our alkalinity is very low (25) and cyanuric acid (CNA) is essentially undetectable. Free chlorine is 2-3.
The intellichem says that CNA should be less than 30.
Our pool guy however says that the CNA should be between 30 and 50 and that pentair can't put that for "legal" reasons.
Questions
1) Do we need to add CNA?
2) if the pH is within normal range, do we need to increase alkalinity?
Questions
