- Apr 21, 2023
- 153
- Plaster
- Pentair Intellichlor IC-40
Does for me. Clear your Cache.Still isn't working.
It would be nice to blow it out and clear the water and seal it off but I'm not sure if I'd blow it towards the pool with nastiesin there. Without dropping the water below its level you couldn't blow it from the pool back to the equipment without it filling back unless you use This plug but youd need to get one that can fit deeper in meaning one size smaller then the one that sits almost flush to the outlet opening so it can be inserted deeper and not have the valve protrude past the end of the hole .Link works for me - to use those caps do you need to clear the line first? Not sure how i would do that if the line at the pad is capped
