I currently have a Hayward SP3215EE TriStar 1 1/2 HP Pump that my pool builder installed that needs to be replaced after almost 9 years. Below are my pool specs:
- 11,000 gallons pool
- Hayward 325 sq ft Cartridge Filter
- PV3 in-floor pool cleaning system
- waterfall feature with 2 foot drop
I live in Arizona so I need to replace my single speed pump with a variable speed pump. After some research, I decided on the Pentair SuperFlo VST Variable Speed 1 1/2 HP Pool Pump because I thought it met my flow rate requirements and I believe my pump is running off of 120V. But when I called a local dealer and they said I needed the IntelliFlo VSF 3 HP Pool Pump because I had an in-floor pop-up cleaning system. I was hoping someone on the forum could enlighten me on what the extra demand is for in-floor pop-up cleaners and whether the Pentair SuperFlo VST would be up for the job. Thank you!
