- Nov 10, 2016
- 31
- Vinyl
- Pentair Intellichlor IC-40
Hi,
I've searched for over an hour and read the online instruction manual but I still have a couple unanswered questions regarding the latest version of the Pentair SuperFlo VS pump (342001).
Are the insides of the inlet and outlet fittings female threaded for 1.5" NPT pipe?
If not, does the pump come with threaded rings and 1.5" solvent weld pipe extensions with O-rings that would couple to the external threads of the inlet and outlet fittings? Or does a 1.5" pipe/ring kit need to be ordered separately?
When programming, it appears that you can set it up (perhaps by using 2-3 of the programs in conjunction) to make the pump operate 24/7, such that it doesn't turn off and require priming on every restart. Am I correct in this speculation? I watched/heard some conflicting info on a Youtube video regarding programming but the manual seems to state it can be programmed to run 24/7.
Thanks for the help!
