After removing the broken valve actuator for the solar heater and replacing the leaking seals in the valve, I noticed the Pentair Solar Touch display is blank. I read on another thread about blowing the fuse when the actuator gets wet. Which it was. The fuse was tested and needs replacing. I have tried 4 stores looking for the 1.5 A fuse to replace it, but no luck. Any suggestions out there for finding the correct fuse for this panel?? Thanks! The fuse is very small. The diameter is .200" and 3/4" long.
