I want to put in the pentair easytouch with screenlogic so I can control my pool with my phone. I also think it will give me better control over the pool, how often the pump runs etc, and I also would like to be able to control the deck jets as well through a control panel so if people are swimming and want to turn those on it's easy to do so.
Right now the deck jets are simply controlled by a ball valve, so when the pump is running I turn the ball valve to allow the deck jets to shoot water. I'm curious to know how I can go about setting it up so that when I press a button on the easytouch or through the screenlogic interface on my phone I can turn that feature on or off.
Just getting started looking into this, but it seems like I might need to install an actuator somewhere to allow this to happen?
Also I have Jandy valves that control suction from the attached spa or the skimmer along with returns into the spa or pool. Can I do the same for those so I can control when the pool is sucking from one vs the other and returning water to either? When people are using the Spa and I turn the heater on, I turn the valve so it's only sucking water from the spa and returning to the spa, and it would be awesome to simply push a button that does those things plus turns the heater on.
Thank you for any help in responding or pointing me to article or documentation where I can learn more about this.
