Pentair Screenlogic Lighting schedules not working
systekd
4
Apopka, FL
I have a Pentair Easytouch system, The Spa light and pool lights are IntelliBright 5G. In the App on my atch, IOS Phone, and PC the lights will come on manually when I turn them on from any location. I have both lights on individual cicuits so I can control each seperately. My problem is, only one light would actually come on at first, but the other even with a schedule will not. I deleted all the schedules and recreated them, Pool Light comes on at 8:45-11;30 PM and Spa Light has the same separate schedule. Seen image below. Neither light will come on when the scheduled time is reached. Again, the lights do work manually when I turn them on or off. Anyone else seen this issue?
Welcome to the forum!
Are all your Egg Timers set to 12 hours?
I suggest you read through Pool Care Basics - Trouble Free Pool and even look at a few of our videos TFP-TV - Trouble Free Pool
What would the egg timers have anything todo with the light schedules on or off? The current egg timers are set for 6 hours on both lights. The egg timer is the duration of time the specific device will stay on if manually turned on correct?
Reactions: murrivets
You have a PSL4 -- that is what they call the Lite version.
The Lite Easytouch only allows 4 schedules and egg timers not set to 12 hours. Screenlogic will allow to set up as many as you like, but the ET will only run 4.
So set the Egg Timers all to 12 hours 0 minutes. The Schedules should then run.
Reactions: guinness
Great. Now the schedules should run as programmed.
You have the max number of schedule/egg timers now as I see the Air Blower Egg Timer. So that is it. You cannot set up any other schedules or Egg Timers.
