Ok first of all I have seen and read previous threads on this very same subject. Point is I never really found a bottom line you can or cannot fix a pin hole leak. Mine is leaking right at the top of the filter on the seam where the filter is bonded together. This filter is approx 7 years old. Some said poxy, plastic welds and only from the inside work others say DONT TRY TO REPAIR ITS DANGEROUS . I always go with safety first but also I consider how much money this will cost to replace and thats approx $800.00. So pool experts out there should I just bite the bullet and replace it?
