My father has this brand of robotic cleaner. Its worked great for a few years. Recently it has powered on(blinking light and started the function tests.) after about ten seconds the motor gear stops turning and it turns off. Any tips?
About the only thing that you can fix is if the impeller has something wrapped around the shaft.
You have to go in and remove the impeller and look to see if string or hair is wrapped around the shaft.. If not, then most likely the motor box has flooded and it almost cost less to buy a new one, than fix the old one.
