Pentair pool light flips gfci instantly in spite of changing breakers.No moisture inside fitting. If I wire it directly and bypass the gfci it will stay lit. Main breaker is rated 25 A as is also the gfci.What couldbe the problem?
@pflood4150
If you're not able to resolve this issue correctly or you find that you are not comfortable performing this critical type of pool electrical work, let me know. I know of a really good independent and licensed pool electrician here in the Phoenix metro area that specializes in pool lighting issues. He is highly recommended.
I probably don't need to remind you of the fact, that a pool light flipping a GFCI is not something to be taken lightly or something that should be "MacGyvered".
I'm always reminded of the tragedy that occurred here a couple of years ago when a woman came home to find her husband assuming "pool temperature". She told the investigators that he was ONLY trying to fix a pool light electrical issue.
Yea, a bit melodramatic but it helps to make my point if you know what I mean.
