Pentair Pool / Intellicenter Settings - Spa Issues
Brem254
13
Central Texas
I'm not sure when it happened, but I believe my circuit settings are all screwed up. When the pool is running, I generally could press the "power" button on the app to start the Spa. However, when I now tap the power button, the pump turns off and I have to select a "Pool High" to start the pump. The spa works as intended once I start the "Pool High". Can someone help me start fresh with my settings?
You need to set a speed for the circuit SPA here...
img_4519-png.623159
Press ADD CIRCUITS...
img_4522-png.623162
