So I was backwashing to remove some of the Ida rain, going to rinse the filter the handle broke off, I thought I miraculosuly found a replacement however once I got it opened and went to replace it the bottom portion was too large and was advised would need to special order
Since I have it open can I just turn the lower portion 180 degrees to the filter position and reattach the top? Or is there more guts down below that get moved.
Pictures
1. the inside
2. where I believe it was set for backwash
3. where I believe I could set it to filter
4. top of multi port valve adjuster
Pictures
1. the inside
