dougingalls
11
Dallas, TX
Hello,
I have a Pentair Mastertemp 400 (almost 6 years old). I have been getting as service heater light (solid red light on the Fenwal Ignition Controller module - Control Fault). The heater will run normally about 50% of the time that we use it. On the occasions that the service heater light triggers, then I open the front panel and pull the 240V (red) 12 position recepticle to restart the heater and it fires up fine. Any thoughts? Is the Fenwal Ignition Controll Module going out?
Thank you in advance,
Doug
