I have 12 year old Pentair Mastertemp 400 heater, which has worked great up until now...I tried to turn it on the other day from the panel (Pentair Easytouch Control System) and nothing happened - completely dead. no power, lights, or errors. I search the forums on this website and found some very helpful information. I followed the troubleshooting from this thread - Pentair Mastertemp 400-Blank Screen-No Power which explained my same problem with same hardware. I jumped the fireman's switch and it worked manually which lead me to the wire connecting the switch to the low voltage panel. I performed a continuity test on the wire itself and found the orange wire was cut somewhere. So I replaced the wire. Interestingly enough it was CAT 5E General Cable 4PR 24AWG IWC - standard network cable. I happened to have a CAT 6 4PR 24AWG cable so I used it. After connecting it to the panel and switch I proceeded to turn on the heater. Nothing turned on but i did receive a 128 R=8 code and the screen went blank. I checked the board under the keypad and no error lights. If I press the pool on button it turns on but the service heater light is also on. Why would it work fine manually when the firemans switch was jumped, but not work now...One thing that I was afraid to try is switching the two plugs on the firemans switch. I don't remember which wire was supposed to be on the fuse side and the other. so I guessed. I did take a picture of the low voltage side (attached). Any ideas on why the code when using the panel vs manually pushing the pool on button? Any help would be greatly appreciated.
