The heater fires and operates correctly. Temperature show about 30 degrees low. It goes goes up from the low temp staying about 30 degrees below to actual temperature. I changed the thermistor and slaw no change. Any suggestions?
ThxThe heater fires and operates correctly. Temperature show about 30 degrees low. It goes goes up from the low temp staying about 30 degrees below to actual temperature. I changed the thermistor and slaw no change. Any suggestions?
YesIs it set to metric?
Does it show the correct set temp?
ThxWelcome to TFP.
Connect a 10K resistor in place of the thermistor sensor. If it reads the temperature as 76F then its the sensor, if not then its the board.
Temperature Sensors - Further Reading
www.troublefreepool.com
Pentair MasterTemp Heaters - Further Reading
Yes to what?
