Greetings everyone... I could use some help.
My heater stopped firing after years of reliable use (heater is about 10 years old). I read a bunch of forums here, including the great HowTo on the heaters in general.
Following those troubleshooting steps, I was able to narrow the issue to a relay failure on the Fenway board. I considered just buying a new relay, but in the interest of "Peace of Mind," I bought a brand new Fenway board (35-662944-013) and installed it.
The heater fired right up. Yay.
But a few hours later, I swapped out of service mode to standard mode and tried to turn on the heater again, and once again, the heater is not firing.
I need to wait for daylight to disassemble and troubleshoot again - but I am worried that something else is going on or worse, causing the relay to fail.
The display does periodically display "91," but I don't know what that indicates, and a search on google doesn't show anything significant.
Does anyone here have any advice or guidance on what may be going on?
Thank you!
P.S. For what it is worth, prior to the initial heater failure, I had been running the heater continuously for about two weeks, keeping the pool at 76 with the outside / ambient temperature ranging from 45-80 (depending on day). Maybe soot buildup somewhere????
Thank you!
