Pentair Lights
sneakykitty
29
Oklahoma
Pentair Intellichlor IC-40
I have read and re-read the information on here concerning lights and recommendations and I can't seem to put a finger on why it is recommended to go microbrites vs intellibrite. I'm not mechanically-electrically inclined so please just dumb it down for me! :ROFLMAO:
My pool will be 14x26, pool builder recommended 1 Pentair Intellibrite in the middle of the wall on he 26 foot side. I just can't figure out why I should change and to how many! TIA
I would recommend at least 3 MicroBrites lights. They are newer, more reliable, and fit in a standard 1.5" fitting (no proprietary niche). Make sure the lights face away from your house or primary sitting area.
Intellibrites have more reliability problems then Microbrites.
Microbrites fit a standard 1.5" PVC pope and you will have more options for using other model nicheless lights if the Microbrites don't work well for you.
Simple enough?
Pentair has a few models of LED lights. They vary in size and type of niche required. The chart below summarizes the light specifications.
Pentair guideline is to aim for 4 lumens per square foot of pool surface. For example, if the pool is 500 sq-ft then you need 500x4=2000 lumens. This would be 4 MicroBrites or 2 IntelliBrite rgb.
Inyo Pools also has a good blog on How Many Lights Do I Need For My Pool? with a table summarizing the coverage of the different Pentair lights.
Jandy has an excellent LED Lighting Design Guide.
