Pentair Laminar Wiring
jbrees
42
Los Angeles CA
Pentair Intellichlor IC-40
Hello we are getting ready to install Pentair laminars that will be connected to intellicenter. Here is my layout.....1st laminar is about 60' from the intellicenter, 2nd is about 40' from 1st and 3rd is about 25' from the 2nd. (pic attached). So my question is, do i need to homerun a 1" conduit to each laminar for electrical if not how would you go about wiring it? As you can see from the pic there is not really a good spot to hide a junction by each one. We will be running separate plumbing to each with individual valve on each.
Do you want to control the light and thumper function of each laminar independently?
Why not run an electrical conduit alongside the water pipe to each laminar?
Thank you. I wasn’t planning on controlling each one independent. But now that you mention it I guess I should leave that option open and run one to each.
Reactions: Jimrahbe
Then you will need a low voltage transformer and a relay in the IntelliCenter for each.
