I have a Pentair intellitouch system. Today, when I turn on the spa overflow waterfall or the spa jets, the pump speeds up but nothing happens at the spa. Same ting with spa jets + heater...heater turns on - nothing at the spa.
This is the first time I have experienced this. I don't see any auto valves moving (assume that should happen when we fire up the spa+heater?) I am doing this at the panel to remove the possibility of a WiFi issue. When the pump speeds up, the extra pressure is being pushed into the main pool area, just at a higher rate - like the valves are failing to direct it to the spa? Also, it says my solar heating is turned on, but it sure doesn't sound or feel like water is flowing from it when I walk over to the pool solar.
System is showing auto an no error lights, etc. Pool guy was here yesterday.
Is it possible my pool guy forgot to flip something or left something turned off that would cause this? I haven't been able to reach him today.
Thanks.
Thanks.
