Good afternoon all, new to the site... back ground is that my WhisperFlo 1 HP is on its last leg... I was stupid and had a home warrantee company fix it instead of doing it myself... end result is I have a POS motor attached to the pump that sounds a lot like a freight train in less than a year. So, now I am going to do it right and install a VS pump. I've settled on the Pentair 2.6 HP VS pump. It is the same dimensions (input and output at least) as the WhisperFlo, so it should be easier to replace. My problem is that my IntelliTouch system is 17 years old and pre VS pumps. So, I need a new mother board and personality board to be able to control the VS pump. You can see that there is no option for th IntelliFlo on the left side of the Remote. I'm not too concerned about the process of swapping out the two pcb's, I'm more curious about what happens after I turn the power back on... I assume I will lose all of my settings and have to re-program everything, but my real question is will the remote show all of the options of the new motherboard on boot up? Or do I need to change/update anything on the remote? Thanks for your help in advance!
