Pentair Intelliflo3 and ScreenLogic connect compatible question
cfunni
1
Houston
I just replaced my intelliflo pump with a new Intellaflo3 3 hp pump. My original system was installed about 5 years all Pentair equipment and all controlled from the screen logic app. My new pump is Pentair Home app controlled and I would like to have everything connected together. Any chance I can get everything running on 1 app?
Welcome to the forum.
You need to connect the new pump to the Easytouch(?) using a RS485 cable.
The Home app is for those without automation.
FIFY.
You connect the IntelliFlo3 to your EasyTouch using the same cable as your old IntelliFlo pump. It should then work with your ScreenLogic app when the ET is in AUTO mode and you use the HOME app to control the pump when the ET is in SERVICE mode.
Reactions: Hulaomr
