My Pentair Intelliflo pump is drawing in small air bubbles, and over the course of about an hour, both filter baskets nearly empty, causing the pump to lose its prime. This issue just started recently. I found a hairline crack in the system, which I repaired with epoxy. The crack is above the water line and doesn't appear to be leaking, but the air suction issue persists.
The pool is 20,000 gallons with pop-up cleaners, all of which are functioning properly. I cleaned the cartridges a few weeks ago, so I’m unsure what could be causing this. I really need to figure it out. Any suggestions?
