Received error code f90052 after motor submerged in water - backyard flooded and water surrounded motor while pump was running. I shut off the pump when I realized yard flooded. Now it won't turn back on. Tried resetting the breaker. Did not help.
I recently replaced my old pump with a new VS pump, Pentair Intelliflo. However, in the last 2 weeks, the pump stopped twice and gave the same error code F90052 and F90052 "Power OUT/OFF" (please image attached). Once I reset the breaker, the pump works fine but I am worried there is something...
www.troublefreepool.com
Power Out Failure
The incoming supply voltage is less than 170 VAC.
The drive faults to protect itself from over current. The
drive contains capacitors that keep it powered up long
enough to save the current run parameters. If power is
restored during this process, approximately 20
seconds, the drive will not restart until completed.
