I've had this Chlorinator for about 10 years and it has worked well, but this season I noticed it has been producing no chlorine. I cleaned it with muriatic acid, I ran the diagnostic that showed it was 60% used up. All the lights are green- good salt level, good flow, good cell. I understand that when it's done the cell light will indicate end of life, but everything says it's OK. Is there anything else to try or is this the end? I know it is not making chlorine because my chemistry is good and the chlorine will not go up- I've had to add liquid. Thanks folks.
