Pentair I10D Wiring Diagram
sbgumble
2
Lo de Marcos, MX
I have a new Pentair pool installed in Mexico and quite frankly the company that installed the system seems very inept when it comes to the power of pentairs automation. For starters I have a dual system spa and pool with seperate valves, pumps and heaters. They installed the I8PS personality card which is for two bodies of water and one system. They completely circumvented the I8PS (nothing is plugged into it). I have now purchased the correct card, I10D, but being very new to this I cannot find what exact components you connect to the I10D and where. I do know the second heater gets connected to the J3 terminal but that was all I could find. Is there a wiring diagram anywhere that would tell me exactly what goes where? Thank you in advance.
Welcome to TFP.
There is no wiring diagram as every system is custom designed and the IntelliCenter setup is a combination of the wiring to relays and actuators and the system programming to tell it what is connected where.
Tell us what you are trying to connect and we will guide you.
Give us a list of your pool equipment to be connected.
Have you reviewed the IntelliCenter Installation Manual and User Manual?
Post pictures of your equipment pad and the Intellicenter panel showing your wiring so we can understand your situation.
