Just did the first backwash in a few months on my Pentair 24 filter, as the pressure was at about 25 PSI (it took a while to get there over summer). This is in prep to SLAM and close my pool.
After backwashing and rinsing until the sight glass was clear, the new pressure reading was 18psi. I ran the filter and shortly after, added two full orange scoops of DE, but the PSI reading has remained just about the same, maybe 1 higher at 19 PSI since.
I expected it to go up a bit right away, so that was weird. I then also remembered that 18 PSI was the starting pressure AFTER I added fresh D.E. last time I backwashed months ago, which is now confusing me even more.
So two questions:
1. How was I at 18 PSI or lower AFTER adding D.E. after a backwash months ago and now I'm at 18 PSI after backwashing but BEFORE adding D.E. now??
2. Does it make sense that I am starting at 18 PSI after backwash and then staying almost the same (19ish) after adding 2 scoops of D.E., or should the pressure have risen up right after? What could cause this?
Thanks.
So two questions:
Thanks.
