Pentair Easytouch control panel not turning on Century 1152 pool pump
Jnix129
1
Oklahoma
I recently purchased a home with a salt water pool. The previous owner told me the salt cell (intellichlor) needed to be cleaned. Before removing the salt cell, I flipped all the breaker switches off in the pentair EasyTouch control panel. After cleaning the salt cell and reconnecting it, I proceeded to clean the filter pump basket and primed the pump (Century SG1152) before closing the lid. Once everything was back together, I turned all the breakers back on. Now, when I turn the filter pump back on from the control panel, the red light turns on to indicate it’s running but the pump doesn’t run (no humming or buzzing, just dead silent). I made sure it was in the “auto” mode. The pump schedule is set from 7:00am-6:55am. Any suggestions on how to get the pump running again. Did the pump somehow disconnect from the control panel?
It worked fine before I started the cleaning process. Any help would be great appreciated, thanks!
Welcome to TFP.
The power to your single speed pump should be controlled by the filter pump relay in your EasyTouch.
Do you have a multimeter and know how to check voltages? If so, check if you have 240V between L1 and L2 on the pump. If you have voltage then your problem is in the pump, If you don't have voltage then the problem is in the EasyTouch.
We need to figure pit which way to look.
While you are there post some pics of your pump and pool equipment so we can see what you are working with.
