I am a new poster to this group. I installed a new Polaris PB4-60 Booster Pump and it won't start. I have confirmed proper install of the pump. It appears to be an issue with the Pentair Easy Touch panel. There are 240 volts going in to the Booster Pump relay and zero volts coming out. I've ensured the Variable Speed Pump is running and to the best of my knowledge disabled any delays. I can't find any programming reason why the power wouldn't be coming out of this relay. Is the relay bad? Is there some other programming that needs to be disabled or reset?
Thank you for any suggestions as to how to fix this and get my booster pump running.
