Hi,
I am about to open my swimming pool, and I had a big doubt.
Last year a new filter was installed, and the old Pentair multiport valve was replaced with a 3-way diverter valve (see picture below).
In the old valve, the filter and the backwash positions were clearly indicated on the valve itself.
The new diverter valve has no writings.
1) What the correct position of the valve for normal pool operation? (i.e. the equivalent of the "filter" position in the multiport valve).
For the sake of communication, let's use the "off" label in the picture as a reference. In the picture, the "off" label is pointing at "3 o'clock".
2) I purchased a vacuum head, and I'd like to vacuum the pool immediately after opening the pool cover. The vacuum head connects through a hose to the skimmer hole. My understanding is that while using that vacuum head, I need to switch the valve to "backwash".
In the picture below, what is the correct position for backwash?
Thanks!
Thanks!
