Pentair Color Sync Installation Problem
BMeekins1
1
Celina, TX
CircuPool RJ-45
I am attempting to upgrade my light switch to a Pentair Color Sync controller. Our pool has 3 Pentair Microbrite lights that are controlled by a switch that is fed off a GFI next to it.
I have wired the controller and it is getting power and the transformer/lights are getting power as they turn on when flipping the breaker.
However, I have run into an issue where the Color Sync controller is not communicating with the lights. I am unable to turn the lights off or change colors from the Pentair home app or the controller itself. Any thoughts on what may be causing this communication issue?
I have attached the wiring with the original switch, current wiring with the controller, and an overview of the transformer.
Thanks in advance.
Welcome to TFP.
Show us pictures of how the ColorSynch Controller is connected.
How did you wire the controller between the circuit breaker and the transformer?
