- Aug 19, 2021
- 1,431
- Plaster
- Pentair Intellichlor IC-40
Pool was finished june of 2022 and I have 5 check valves installed (1 Pentair which was added new recently)
3 are pentair and 2 are jandy ( not sure if it is relevant but 1 of the jandy is basically a coupler, check flap removed as the plumber installed it in error). The 2 jandy are installed facing forward, the 3 pentair are facing up. I noticed a leak on the check valve for the solar and on closer look found that the lid was cracked. Inspecting the other pentair that has been installed since new it appears to have one similar crack forming. The jandy's are fine. I ordered an atie replacement for the leaking one and have installed it.
Any clue what might cause this and how to prevent it?
