17 year old pool and equipment. A&A in-floor cleaning system. Whisperflo Pump motor recently replaced. Recently started blowing large amounts of air through pop up heads on startup.
The filter tank starts draining (almost as if the air relief valve was open) as soon as the filter is turned off. There are no visible leaks anywhere in the system and no bubbles in the strainer when running. After shutoff, water appears to be running backwards through the strainer into the pool. Filter o-rings and relief valve recently replaced. Local pool repair tech with a good reputation replaced an in-line valve (small, with a clear top), but left stumped as to why the filter was draining.
I'm concerned that the massive air released through the pop-up heads is going to cause damage. Any thoughts on what is happening here?
Thanks!
Thanks!
